Dayton DSP-408
  • 5
Gunk
CarAudio.com Regular
237
37
Ohio
Do you guys give this DSP the thumbs up? Just trying to get a DSP with 8 channels that doesn't break the bank.
19429
This is a very capable and good budget DSP and this is coming from a guy who owns JL TwK88 and HELIX DSP’s.
Pros:
  1. Sounds as good as the more expensive DSP’s when set up right.
  2. Cheap especially when on sale.
  3. Bluetooth works well with iPad app.
  4. 10 band parametric filters are powerful.
  5. Mixer works well.
Cons:
  1. Remote introduces noise into the system (Don’t buy it)
  2. Software can be buggy sometimes.
  3. < 3.5 volt outputs.
  4. Time alignment by distance is off (use online calc instead and input in ms).
  5. Owners Manual *****
  6. Presets are slow to switch.
I had one, but it was a little "over my head." If you like to tinker with stuff, then, you will like it. My installer had no clue what to do with it. So, I basically gave up on it. Be sure to do your homework on it before install day. I made that mistake and fried some tweets. The only thing wrong with my Dayton DSP was me. Very nice piece though.
Pros:
Cons:
Another pro you can add here is that it has a DC input power supply option as well as can be hardwired. So this can be an ease of use in home or car audio both. I was not aware of the noise induced remote. How did you conclude that? I never touch my remote after setting the level to 57. I might just unplug it for now...
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced...
OK, I am not the person to ask about SQ. Yes, I know a fair bit. Yes, I can offer quite a bit of opinion and fact on amps/speakers/etc. My entire...
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Gunk
Gunk
Ohio
Jcsaudio
    May 24, 2024
