Dayton dsp 408 question
  • 4
Jimg
CarAudio.com Regular
217
13
I am not looking for perfection
I know the dsp is limited with 10 bands vs others at 31
My question is. The Dayton only has an output of just under 3 volts before clipping
With proper amp gain setup is 3 volts enough to get good sound qualify
Yes
Your amps should produce the same sq from 0v-whatever max input is.
Remember when the volume is low RCA voltage is to. It's a low voltage analog signal.
High RCA voltage is good for resisting noise but that shouldn't be needed with good install techniques.
Yes
You don't care if you have 2v or 5v pre-outs?
Some people make to big of a deal about high voltage rcas. I had a pioneer head unit with smart sync ( 31 band eq, crossovers TA etc ). I replaced it with another Pioneer head unit, with the only differences were 4 volt outputs and different display colors. After applying the same settings and resetting the amplifier gains, the sound was exactly the same. The higher voltage rca’s made absolutely no difference in the sound.
OK, I am not the person to ask about SQ. Yes, I know a fair bit. Yes, I can offer quite a bit of opinion and fact on amps/speakers/etc. My entire...
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Tuning as low as PE suggests will problematic (long port) unless you go with a passive radiator.
Pay attention to the width to height ratio of the port. The further you deviate from a square shape, the less efficient the port becomes and it...
Ive been looking at amarican bass xd 1222 or 1244 ,and sundowns e series, they both seem very good , can't verify sound quality tho but I know...
37
9K
Jimg
Jimg
dragon.breath
    May 23, 2024
SPLBassJunkie
    May 21, 2024
