Dash smoke plz help
Time to start tracing some wiring down man. Might as well remove that HU and bench test it to start with. Remove the fuse at the battery for the amp supply on the safe side and prob the supply fuse for the HU even
Thank you. I'm positive the head unit still works cuz it did and all 4 speakers worked after the smoke incident
I doubt it is OEM wiring. All wiring back there is protected with a fuse. Only if you used too big of a fuse for X reason, then I think it would be a component.
Yeah but if it's not OEM wires then what is it its the most base model 1999 tacoma. There's not much under the dash and my next question is what if it fried something that the wire is going into
Dylan brothers
CarAudio.com Newbie
Dylan brothers
Spokane wa
spokey9
