Customize Sub Woofer Box
It all depends what your working with. What size subwoofers, ts parameters, how many subs, sealed or ported? All kinds of factors really. State all applicable.
As stated, we're going to need a lot more information than what you've given us. Subwoofers should never just be thrown into the 'average box', contrary to anything you've heard. A box should always be built around the drivers that it will be housing, as 90% of the driver's performance is actually determined by the enclosure that it's in. Give us some info on your equipment, and we'll do what we can to help you out.
What subwoofer(s) are you running?
How many are you running?
How much power will you be running?
What's your goal for the subwoofer (sound quality/loudness)?
What will be the enclosure's main use? SPL/music?
How much room do you have to work with?
Would you prefer a ported or sealed enclosure?
If ported, where would you like your tuning frequency to land? This will be mostly decided by the music you often listen to.
There are many, many different factors that go into an enclosure. People don't ask the questions for no reason - it's so we can help you get a box that will suit your needs; or at least come as close as possible.
Ans:pioneer 12 inch
Ans:- Two Woofers
Ans:-1400 watts , 300 RMS
Ans:-Both
Ans:Music
Ans :- Ive altima sedan
Ans Which give good quality
What subwoofer(s) are you running?Ans:pioneer 12 inch
Ans:- Two Woofers
Ans:-Both
Ans:Music
Awesome, we're getting somewhere. I've got a few questions just to clarify, though.
Could you provide us with a link or a model number on your subs? Pioneer makes a few different drivers, so I'm not quite sure which sub you have yet.
Also, how I understood it is that you'll be running 300w RMS to each subwoofer. Is that right?
Thanks for answering some of the questions, it really helps us out when we try to put something together. We can only help you as much as you help us. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
472
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
502
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
604
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
743
kapirani
kapirani
UAE
The Audio Guy
