CTX6M IMAGE DYNAMICS 6.5" ordered.
  • 2
my2006c6
Hello, I m out of touch with speaker selection's , but i recently finally got my complete system upgaded in my 2006 vett Convertable,,
Amp- Boston Acoustic, GT-42-4
H.U-Pioneer AVH-X3500
Pioneer TS-SW3001S4 SVC 4OHM down firing sub, in pioneer box
Polk DB6501 Component set.
Sooo,,, any thoughts on how ill like the CTX6M IMAGE DYNAMIC 6.5 Ive ordered, compared to the polk. ????? - There is just so much info out there on choices, that i thought this would be a step up from the polk's. Ill be just adding tho's mids for now and leaving polk tweet's,and crossovers in..
Any thoughts or ? //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I work at ID and i personally have them in every vehicle. best bang for your buck drivers! Questions, did you buy the component set or just the mids?
Thanks.. I just bought the mid's... As money is tight. So i thought i use them along with the polk db6501 tweets and crossovers.. Polk cross overs look very cheap. Just my thought.. Not sure how the polk tweet/cross will sound with the I.D.'s
Any ideaa guys, if i should order diff 2 way crossover's to run with my CTX6M IMAGE DYNAMICS 6.5",, that i have ordered... My current set up has polk DB6501.crossovers in place right now... --Do you think thier just as good or better than I.D CROSSOVERS
Or any sugestions on a set of low price units under 50.00 -to run with the I.D speakers..
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Try to reset again and if that doesn't work, try updating the firmware. To update the firmware for Alpine X800D, you can follow the instructions...
This head unit has no power antenna adapter. So the image you are getting is not coming in from the correct program. Like if you were on an AM...
Absolutely. I have an IDMAX 12 in a 1.65 cubic sealed box on 900 watts and it sounds great. You won’t be disappointed. Pull the trigger.
23
3K
my2006c6
my2006c6
United States
my2006c6
winkychevelle
    May 24, 2024
1aespinoza
    May 23, 2024
