crossover installation
  • 3
thinnz
NZ
I've just started installing some Lightning Audio S1.62C Components and was wondering where the best place to install the x-over is...(close to the HU or the speakers) as I am a newbie to this, can anyone help?
i'm not an expert on this but most systems i've seen have the xover near the amp. with my old amp and xover they put the xover under the amp under my seat.
to make a long story short, my opinion is by the amp.
my bad, by the speakers for componets. i've seen the xover in the doors w/the speakers.
The x-overs for the components are usually closer to the speakers. I'm assuming that these are front door speakers so there isn't too much room to work with. I have installed 3 sets of components in the past. 1 set of x-overs went under the seats (cut small hole in carpet for the wire), 1 set went under the dash board (worked nicely), and the other set went inside the doors behind the panels. This was not a good idea because I didn't noticed the water spots inside. After the next rain fall I had a pair of shorted out x-overs.
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
512
On another note, if you're competing in SPL, you might want to check around at what the best crossover point is. These two drivers (your 6.5s and...
8
I usually cross at 80hz And as a drummer The meaty end of a kick is 40hz..like bands such as Metallica 50hz is a U2 kick
9
thinnz
thinnz
NZ
natem33
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
