Crossover Help
  • 2
hyrolincstmz
Im running 3 sets of compts so i have 6 cross overs and am wondering the best place to mount them in an ext cab full size chevy
Thinking to avoid the door all together since i saw condensation in there = bad for electrical
My thought is to build a small MDF rack and mount them in the back behind the seat next to the amps (is having longer speaker wire like in this situation affect SQ?) oh and im running 14 gauge speaker wire. . .
it is fine to mount them by the amps, or under the seats, or under the amps, etc. i avoid door locations due to moisture as well. some crossovers offer setting adjustment so you'd want access to them for tuning.
a little extra wire won't hurt anything. the most important part is making quality connections.
There's definitely quite a few that can give a better answer, but IMO, it's (1) 8" sub. It's supposed to be quicky and jabby, not a power...
7
For the front and rear speakers set the high-pass filter around 80-120 hz depending on what sounds better with over driving the speakers (you'll...
Agreed. I was actually thinking of building a 3-way passive and I compared the cost to a Dayton DSP and it makes no sense to go passive.
10
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
520
hyrolincstmz
hyrolincstmz
Folsom, CA W$R
keep_hope_alive
Decebal
    Jun 10, 2024
