Corrosion protection for power cables?
  • 4
if you are worried about the corrosion, there isnt much you can do other than replacing components periodically, what you could do is when you are completely done with all your wiring and everything works correctly, you could wrap electrical tape around the exposed parts of your wiring to prevent water and dirt from getting on it.
You can buy battery post protect spray at Orileys, or Autozone for about $6 bucks for a small can..or if you have some type of Grease such as Vasaline or patrolleum(ms) type grease, a light coating will work very nicely,and is cheap..keeps the dirt away from the post as well as water proofs and protects from corrosion.Clean very well and then apply
Don't buy crap wire... I have welding wire and it's not corroded.... Buy tinned copper if your worried
It's the Excelene welding cable, 2/0, non-tinned terminals. The shrink wrap I use is triple layer so it seals 100% water tight. It's just where the terminals attach to the battery post. I just like to make things as protected as possible in the engine compartment. Yeah, I can clean em if necessary, but I prefer the ounce of prevention over the pound of cure.
I had used the sprays before with limited success. Was just wondering if you guys did anything differently. I might give the grease/vaseline idea a try. I've seen that done in some heavy duty applications.
Ok thank you, I'll check where the remote wire is connected and get back to you.
Ill try it when I get the amp back, especially if the forbidden protect light goes on. I don't think it's grounding out anywhere because I still...
8
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
6K
Disconnect all 5 speakers and the rca cables from the amplifier. Turn it on and see if it still goes into protect. If it does, bad amplifier. If...
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Sguirrelfeather
Sguirrelfeather
Mountain Home, ID
Sguirrelfeather
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
