correct airspace for L7 12s
  • 5
try kicker.com
Mounting Depth (IN.,CM) 6-11/16, 16.9
Mounting Cutout, Square (IN.,CM) 11-1/16, 28.1
Min Rec Sealed Box Volume (CU. FT., Liters) .88, 24.9
Max Rec Sealed Box Volume (CU. FT., Liters) 2.0, 56.6
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 3.25, 92.1
kicker specs are general specs tho. and anyone that uses kicker knows to add 25-50% to the box specs and tune lower than they call for to make em get louder and sound better.
i promise you if you put 1 in .88 cf sealed it will sound like pure asssss
yeah i was saying 10-12 as a minimum. they sound horrible in small boxes.
gotta remember a square sub 12" is pretty much a 15" round on cone area so build accordingly //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
827
You stated you have an SIA 3500 right now. I would run it for now with the supply for the demand, until you decide you want more power and have...
665
mr.michael
BOB SAGGET!
mr.michael
cA
SicAudio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
