Corolla 2003 CE Audio help
  • 2
cbraafhart
Hi i'm new to the forum and i would like to know this.
I've visit the website crutchfield.com for some research on speakers that would fit my car but i'm looking for a concrete answer.
On the website i saw that 5.25 inches may fit the front speakers but also the rear speakers but i would like to know what other options i have in size that would fit in the front and rear speakers. and what brands would you recommend buying.
You can fit what ever you want if you customize the door panels and cut some metal. It all depends on budget. If it says you can only fit 5.25 speakers in the front, then thats what you can fit with just a direct drop in.
Maybe someone on here can answer if they were able to fit 6.5's in a corolla with little to no modification.
As for brand, it all depends on how much you want to spend. There is so much to choose from.
Corollas **** for audio, lol. I had one as my first car and mine was a 94 and only had 4 inch speakers in the front and like 6.5's in the rear. So weird.
These are the parts I think I need, can someone let me know if this looks right? Headunit: 9" Toyota Corolla 2003-2008 Android 10 QUAD CORE Door...
I just bought a pair of SoundQubed QP-MR6.5 speakers powered by my Taramps DS440x4. My 6x9s blew when I got the amp because I tried to tune the...
You're going to run into some issues with weight on the arse end of your car at some point and there's a limit to how much suspension...
6
Check out Focal. I believe they have direct replacements for many Toyota's...
4
Make sure they provide a warranty for theyre work and everything you buy.Ask to keep all the Boxes that every amp and speaker and sub comes in...
cbraafhart
cbraafhart
Netherlands
Moofs
