tutubebe99
Banned
Convert HD videos (in the format of M2TS, TS, TP, etc.) on Mac
Aspeople have higher and higher requirements about the quality of theirwatching videos, more and more HD videos are emerging. Nevertheless, atthe same time, these videos bring people many format troubles. Have youever met setbacks while converting your on-hand HD-DVDs, or Blu-rayDVDs to other formats like MP4 for playback on your iPod, iPhone? Orconverting to MOV to do further editing with iMovie? Or converting to3GP for playback on your cell phones? Or converting to WMV for playbackon your Zune player? If so, you need to go on with this article,because it discusses what HD videos are, and how to convert HD videos (in the format of M2TS, TS, TP, etc.) on Mac?
First of all, what are HD videos?
From Wikipedia:
High-definition video or HD video refers to any video system of higherresolution than standard-definition (SD) video, and most commonlyinvolves display resolutions of 1280×720 pixels (720p) or 1920×1080pixels (1080i/1080p). Usually these HD videos are recorded in theformat of M2TS, TS, TP, etc.
How to convert HD videos (in the format of M2TS, TS, TP, etc.) on Mac?
Next, we will talk about how to convert HD videos (in the format of M2TS, TS, TP, etc.) on Mac with Pavtube HD Video Converter for Mac.
1. Download, install and then launch this program.
As soon as you have run this converter, the following interface will emerge.
2. Add files, set output format and destination folder.
Click button "Add" to input HD video files, after that, you can select format according to your demands by clicking the drop-down list of "Format".For instance, to play on iPhone, you can select MP4; to edit withiMovie, you can select MP4 or MOV; to play on Zune, you can select WMV,etc. Moreover, if you want to join multiple files together to be asingle file, you can check "Merge into one file". At the same time, you are allowed to specify where to load the output files by clicking "Browse".
3. Set advanced settings.
Want to adjust some audio or video parameters to optimize the generated videos? Slightly click button "Settings", parameters like bit rate, screen size, frame rate, etc. can all be reset based on your requirements.
4. Convert
Once you have finished the above settings, you can start converting by pressing "Convert". This program can completely finish the converting process at speed with extremely good quality.
Additional Tips:
1、There is no need to worry about audio-video out of sync problem.
2、Capture the specified video clips to do converting is permitted; "Trim" function can help you realize it. Furthermore, the function of "Crop"can help you adjust the screen size or cut off the black edges of theoriginal HD videos.
3.、Text, images, GIF animations, and videos are all allowed to add as watermarks.
4、Audio replacement is available; you can take place of the original audio by your specified audio.
From Wikipedia:
4. Convert
Additional Tips:
