Confused about amp suitability
  • 4
Lozi
Hi
i am building a retro-ish system in my van and I have collected 8 subs. 4 12” and 4 10” which I’m not sure sure if it’s a good idea mixing sizes but it’s all I could get these subs are not that common.
they are
Infinity Kappa 120.1se
http://www.cieri.net...l box etc.).pdf
Infinity Kappa 100.1se
i plan for the subs and speakers to all be from that range but I want newer amps to power it all.
i like alpine so have been looking at their V power amps MRV-M1200 and MRV-M500 x2.
the subs are 300wrms and 250wrms respectively at 4 ohms and the amps make 1200rms and 500rms which I thought would power them perfectly but they produce that power at 2 ohm so does that mean it won’t work?
Thanks
So I guess giving up all your cargo space for a load of mediocre budget subs and spending hours/hundreds on enclosure design/construction when you could achieve similar sound with a good pair of 12's is the "retro-ish" aspect of the set up you're going for?
They're svc 4's, right? Each set of 4 can run at 1 or 4 ohms. The 1200 needs 2 ohms for optimal power. You're either stuck at 150w per sub running at 4 ohms (but if you're going to do that you could just run all 8 with one amp at 150), or pushing the limits of the amp trying to run at 1, hoping impedance rise keeps it safe. Looks like DCR occurs at ~100hz -- if you low pass at ~80hz or less it might work.
Two mrv-m500's on the other 4 would be fine since you'd run a 500 per pair of subs getting you 250w per sub.
just run the 12's or sell all and get 2 15's (correct ohm load for amp u will have) that'll work and get new sq s2250 or simliar to power 2 15's ported (u will need to upgrade big3 wires and maybe 2nd battery for that amp)
Thanks for the info guys, the truth has turned out not to be the answer I wanted as I guess it won’t work.
These are old subs but the reason I wanted to build s big system around them is I have had 2 of the 12’s since they were new in sealed enclosure and I have always been really happy with them. Now they are really cheap to obtain I wanted to build the system I couldn’t afford when they were new as they were decent back in the day. I’m not trying to get the optimal setup or anything I just wanted to try and install them in the van in a sealed enclosure for seemingly the wrong reasons lol
Amplifying them is an issue it seems anyway as I don’t want to spend 1000’s on amps to run these old subs so I’m not really sure what to do now. I want to try and stick with them if I can but it’s not looking good I guess.
u can get a $180 sq1250 amp (or similar) and 2 $100-$150 12's or 15's ported and be louder than all that sealed with low power.
It’s abit of a nostalgia thing to be honest so buying a load of new stuff wouldn’t scratch that misguided itch. The further 6 subs I have bought on top of the 2 I had only owe me about £80 lol
A lot of the old school subs were more efficient and didn't need as much power as the subs today. I would look into equipment from Vibe, I'm pretty sure they are based out of the UK, they seem to make a good product and have a big following.
yeah like kush said newer subs just require more power.. all the subs i had yrs ago were 150-350rms light subs with 5-600rms amp in sealed box (some of my old box pics are in my gallery)
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
5
Yes. I do not fully understand the question, but if the manufacturer suggests such a big port, it is probably because it has a high QTS. If it...
Dayuuum!! LOL. Going CHEAP sometimes doesnt pay..LOL 💩 💩
13
Hey guys I'm new here I'd like first and foremost that I'm not greenhorn but I haven't been an installer for 10+ years either. So the issue I am...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
107
Lozi
Lozi
Towcester, UK
Lozi
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
