Comparison Test : 2 VFL 150.1s v 1 XX Colossus
  • 6
btnhfan
Hail to the King Baby!!!!
Test results will be up tonite.
2 hc2400s in the back and 2 12" SX subs. Not changing anything except doing a direct swap at 1 ohm stereo, then .5 ohm mono.
Heres a few comparison shots
what's the rated rms that both of these should put out at those #'s?? i know i could look up the colossus but i figured you're on and well you dont have to look it up:p:
I will check that out when everything is done
Heres an interesting note...
I went down 2 freqs from what I burp at with the VFLs, and the score just went up
Now I am .2 down from the VFLs
Im gonna tinker with the settings now.
I guess you can say this is a very strong amp from being almost as strong, if not as strong, as 2 vfls.
colossus is 3200w mono at 2 ohm, I think 14.4v
VFLs are 2000w at 1 ohm at 12v
is that 2kw per vfl or what?? i used to know those amps well but that was when they first came out and people made such a big deal about them.
Yes 2kw per amp
I cant find my dmm, but I believe the coils on the SXs are something like 2.6, Im not exactly sure.
If thats the case, then its .65 dcr, not .5
And 1.3 dcr
wow that is impressive i think. what kind of voltage are we talking?? obviously you're a noob so i'm not sure if you'll know this:p:. thanks for the comparison though man i'm sure a few peeps were wondering about the colossus.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
776
270-ounce triple stacked magnet on the 12", 1200 watts RMS @ $219? That's sick!
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
399
But then you could just use the volume knob to rather than pay for earplugs.
766
btnhfan
btnhfan
CT/ GA Tech, Atlanta
bigbassman
    May 18, 2024
    May 18, 2024
