CMAX
  • 2
Bass so loud it HZ
CarAudio.com Regular
I'm running a 120 large cell cmax atm .I just had a guy try to trade me a sleeve of the small cell and everything to make it for some amps I have.it would save my quite a bit of money . I don't see it being a problem beings they are the same voltage but will it be a problem if I run the large and small cell together just in separate banks obviously ? Also what kinda voltage would i be looking for on a sleeve ? . Ik I won't be able to tell if all the cells are good without taking it apart but wondering if there's like a general voltage for them to tell if they are good or bad... TIA!!
Assuming they're resting around the same voltage I'd think you'd be OK to run both banks in parallel. No way to tell if you have a bad cell without pulling apart the bank and testing each individually.
That's was my thought on it .ik they have different c ratings and the small cell would prolly be doing alot of the work but I'd think it would be ok .
Hmmm, taking a stab here. This assumes you can use (and own) a volt meter and can test the individual cell(s). Here is a link that might help...
My budget was involuntarily reduced recently, that along with the cmax modules I was looking at were not the correct ones for car audio...
Bass so loud it HZ
Bass so loud it HZ
IN, United States
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
