Clamped AQ2200s @ .5
Skip01
Diggy
7,339
Marrero,LA
First off, take it for what you will, dont have True RMS meters or what not, just a Craftsman DMM and Clamp meter...so it is what it is //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
116 Volts
34.3 Amps
3944 Watts
12.7 Voltage
3-4 seconds into burp
.5 wired to 3.3ish rise, **** SMALL BOX //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
So thats what i got....tad clipping..but not full
Let the bashing beginnnnnn //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif:rolleyes:
116 Volts
34.3 Amps
3944 Watts
12.7 Voltage
So you are saying you have the amp wired down, and rise is bringing you clear up to 3.3???
Since the meters weren't true rms typically you multiply those #s by 0.7 for an estimated true rms reading. Also whether you used a peak hold feature and the exact frequency played can skew the #s a little as well.
So each amp saw 1.65 ohm after rise(3.3 ohms strapped)??? Not bad...that sounds about right.....thats not a bad imp rise either...about how much mine rises in my box.
Skip01
Diggy
Skip01
Marrero,LA
Skip01
Latest topics
