Civic SI engine swap idle problem
stoker42
can you dig it?
245
MI
Alright i have a 1999 civic si with a b18b block and gsr head so its ls-vtec. WHen i cold start it it does not want to idle and there is a strong smell of gas. Could the problem be air/fuel ratio? Once the car is warmed up a little it idles perfect and you can shut it off and restart it without a problem. Any help is appreciated
What ecu ? P28 or stock p2p
Still have knock sensor ?
---------- Post added at 09:21 PM ---------- Previous post was at 09:20 PM ----------
I also forgot which 2 plugs look identical but u might have reversed them
sorry guys havent checked here in awhile. Its a stock ecu an its been relocated to the glove box for whatever reason idk. To resolve problems you are talking about would i need to take it in somewhere or are there tests i can do to narrow it down?
Polk Audio DB Series with or without an amplifier. MM Series on an amplifier
733
Looks good so far. If you ever need more up front, Q-forms makes some kicks to fit that civic, we use them in my brother's with good results...
Hello there! I'm gonna own a Civic LX pretty soon ( the one with the touchscreen ), and I'm wondering about a few things ... In my current setup...
problem was the LOC burnt out when I had touched cables. got a new LOC and now all is working. have to get the gain right, lights flickering with...
stoker42
can you dig it?
stoker42
MI
stoker42
    Jun 15, 2024
    Jun 15, 2024
