Choosing an amp for the Focal K2 Power 165 KRX3
  • 1
engdb
Hi, Guys.
I got a good deal on the Focal K2 Power 165 KRX3 3-way component speakers.
These were originally not the speakers i ordered, but due to delays i got these for a really good price.
However, i'm a little bit confused about amping these bad boys.
Crutchfield says the following:
Important Note: Focal strongly recommends using a 4-channel amplifier to drive the 165KRX3 component system — two channels for the woofers and two channels to run the mids and highs. The 165KRX3 crossover can be set up to use a 2-channel amplifier, but it would present a load of less than one ohm per channel which most amps cannot handle safely.
Link: Focal K2 Power 165 KRX3 6-3/4" 3-way component speaker system at Crutchfield.com
I am thinking about using the infinity kappa four amp, it's got a decent price, very good reviews around the web, and i already own an infinity kappa one mono block which i'm very happy with.
Link: Infinity Kappa Four 4-channel amplifier — 125 watts RMS x 4 at Crutchfield.com
Will this amp do the trick?
Please help!
Thanks,
Daniel
Not at all, amplifiers have gain control to attenuate the output to safe levels.
6
I've moved this post to installations. Can't work out how to delete it here.
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
5
If you're shopping in the 10 cents per watt and under department you should probably expect dubious designs and third world build quality from...
17
engdb
engdb
Narvik, Norway
engdb
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
