chevy avalanche enclosure. or no enclosure?
  • 3
Seehafer27
hello, i have a 2004 chevy avalanche and i want to put a system in it but i still am going to use the bed. so my question is would it be good to put an enclosure in and just take it out when i wanna use the bed (won't be that often) or just do a normal box, but if i do a normal box could you even here the base? ( 2 Audio que HDC312 on 2 audio que d1200)
okay, so i want to put the subwoofers in the bed. if i did an enclosure i would take th mid-gate out and fit the enclosure there so its behind the back seats. if i wouldn't do that i would do just a simple box and put it in the box. what im wondering is if the enclosure is worth the time and money.
a sealed box is something a novice can build for cheap, when you decide you want more you can go ported with the same subs and amps and have a lot more output
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
683
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
I would add two more of the same subs and look at selling the 2k to go towards the funds of a decent 5-8k mono amplifier and new enclosure
Seehafer27
Seehafer27
Corona, SD
smd4life
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
