Check out the big ....... load ......
Thy ~
You really have too much spare time on your hands, don't you?
Good luck with the project, guy. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Set up a circulation system using (can't think of the proper name) a copper pipe wrapped in a coil, then have the water in the bucket circulating through the coil w/ the coil in a bucket of liquid nitrogen. That ought to suffice for some serious cooling.
By no means take my crazy ass ideas seriously, I'm just thinking outloud.
wow, new turkey fryer //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
if this unit is going to be stationary, go to the junkyard and get a nice big huge car radiator. try and find a car that was damaged from the rear and yank the sucker out. you might be able to get it for like $30. then get a powerful outdoor pond pump
http://search.ebay.com/search/search.dll?cgiurl=http%3A%2F%2Fcgi.ebay.com%2Fws%2F&fkr=1&from=R8&satitle=pond+pump&category0=
and then set up the radiator\pump outside [with a fan if you feel the need] and put a radiator fluid\water mixture in there and hook it all up to a switch //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
use copper tubes for more heat dissapation too //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
that is to say, that this setup is quite stationary and you wont be moving it all around.
if its got to be semi-portable, you could hook up some hose-type connections with quick connects. [like on air tools] so you can unhook the setup quickly with minimal leaks as well. i would drill some holes thru the wall to outside and put copper\steel tubing through it and put spickets on each side, then just use some garden hose-esque connectors.
These are decent budget subs. The box design isn’t bad at 5 cubes for these, but I’d drop it down just a little and raise port tuning up to 32...
And even then the Demons are a nice subwoofer. Heard a pair of those in the 10" locally Monday afternoon on around 1,200 watts and for a sealed...
9
HI all - I don't have a windows machine and thus can't use WINISD, so I've been playing with speakerboxlite.com Can someone cross-reference this...
thylantyr
thylantyr
[Yoda] Belong to us all your base are...
thylantyr
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
