Charging Batteries Hooked Up
  • 7
Meka
Prestons a *****
1,733
Manhattan,KS
I have an xs3400 up front and 6500 in the back. I use an xspower intelicharger to charge the batteries. Usually, I take the batteries out of the car and charge them both separate. Is it safe to charge both batteries hooked up to the car/amplifiers? Would save me quite a bit of time, but I don't want to damage anything.
Yep
I used a 2 amp smart charger and my mids/highs amp took a ****. It was playing just fine before I parked in the garage. Hooked up the charger overnight, came in the morning to hear this playing.
Yes i charge all 3 of my batts in the car...save urself the time and work
Not good for introducing new guys to lithium Lots of burned down cars from user error because the tech is new and people are ignorant.
24
3K
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
14.6 is max charge for headway. 3.65 volts per cell. There should not be any voltage drop from your alternator wiring to battery so 14.8 is too high.
How often are you charging? I charged mine once when I built it over a year ago and maybe a couple times while I had the car pulled apart. I...
For the pt cruiser, neons, and other pcm controlled charging systems these parameters need to be altered with tuning software. The two tuners I...
6
Meka
Prestons a *****
Meka
Manhattan,KS
SPL.Pantie.Soak
Decebal
    Jun 10, 2024
