CDT Audio MX-369/pod 3-Way Components
  • 1
trumpet
Barry Schanz
1 set
3-Way Components
Some items removed from the boxes for photos. All are new.
Description
Tech specs:
  • Frequency Response: 30 Hz - 20,000 Hz
  • Power handling: 200W RMS estimated
  • Impedance: 4 ohms
  • Mounting depth: 3.5" for the 6x9
What makes you think an audiophile quality 3-way system is out of your grasp? Too complicated? Labor intensive Factory speaker locations are restrictive?
CDT Audio MX-3 Systems install effortlessly and get you on the fast track to audio nirvana in the car. How Is It So Easy?
The 4 Facets of MX-3 3-Way Systems
  • Flexibility. We can't stress this enough against competing systems. These systems can be tailored for anything you want, even as a 2-way that can be upgraded to a 3-way.
  • The most powerful and flexible 3-way/2-way crossover on the market, the MX-1000SX.
  • The incredible 2" mid/tweeters, available in flush mount or pods. Quick installation onto the kick panels or in your factory midrange location.
  • 1" Imaging tweeters that install with literally zero holes to drill.
CDT Audio engineers have created an engineering marvel which opens the door to unique and easy installation of a variation of front-mounted 2 or 3-way systems using a mix of speaker components, adjustability, and tuning you've never been able to do before.
The MX-1000SX ultra flexible EQ module will act as a 2 or 3-way crossover depending on your specific system installation. This unit is specifically oriented to the use of very small 2~3 inch midrange drivers in a two or three way system. This unique crossover marvel offers interactive crossover and adjustability of the mid-range and tweeter, and a switchable conventional second order or high-tech elliptic 5th order filter to cross over the tweeter.
This dual-order tweeter crossover highlights the new and unprecedented functionality of this unit.
Contents:
  • 1 pair HD-690CF 6"x9" subwoofers, 3.5" mounting depth
  • 1 pair ES-020 2" pod mid/tweeters for surface mounting on the kick panel or door panel
  • 1 pair WS-100i 1.1" silk dome windshield mount tweeters
  • 1 pair MX-1000SX 2-way/3-way flexible crossovers
Check the mounting depth available for these 6x9s. You will need 3.5". Many vehicles do have trouble fitting these. I have a 3.25" deep 6x9 sub in stock to substitute if needed. If that won't fit we need to go down to a round 6.7" driver. This is typically the most complicated part of the installation.
$599
Shipping is free to the Continental US.
Factory warranty of 1 year, upgradeable to 5 year warranty for $10
All product is the latest from CDT, hot and fresh.
Ships from North Dakota.
Something to sweeten the deal, various tweeters to customize your own 3-way system:
2" flush mount mid/tweeters to substitute for the pods
trumpet
Barry Schanz
trumpet
St Cloud, MN
trumpet
