can someone please help me with building a box for my single cab? a few questions to.
  • 2
DieselFanatic
ok so i want to build a box my first attempt was pretty much a fail as i dont know what im doing when i t comes to it nor do i know how to build a box to any kind of specifications? not to say the box isnt actually pretty strong it was made out of chip board which i know i know doesnt carry sound waves well and project bass well i pretty much built it out of boardom and to see if i could do it tho. NOW im getting more serious. i want to build a box for 2 10" Audio Q street duty sub woofers i really like the sound of 2 10" subs over a single 12 being they seem to have a crisper sound faster response and just sounds less sloppy. would you even recommenced 2 subs for the air space i have being a single cab truck? my amps will have to go in my camper shell there is no way around it. i think i want to make an adjustable port i think it can dump out below the seat or would that be a bad place to have vent? the thing is i have no idea how to build anything to what size its suppose to be or how to even really make a box the way they are suppose to be made. my dad is a general contractor so i have access to any tool ill need including air compressors nail guns drills skill saws jig saws levels squares tape measures table saws to name a few. anyway rag on me if you will here is my first box (attempt) i built out of messing around just so you can get an idea of about how big (or small) the box can be the one in the pic is the biggest i have to work with tho i guess i could go taller? ohh be sure to make fun of the "ports" too //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
uhhh... //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Use MDF or birch for you box....and use this site to help you design it.
RE Enclosure Calculator
As for box size, per 10" will need about 1.2-1.7cuft and for a 12" you'd need 1.7-2.5cuft
Two 10" subs wont sound any better than a 12" no matter what anyone has told you...they will just sound louder due to more cone area.
I would post more info..but your paragraph is pissing me off...
right i know that box is TOTALLY trash im not gonna use it like i said it was for fun i had the stuff lying around wanted to do get a general idea. also i found this image floating around and was thinking hmm maybe if i build 2 twin boxes or one box with the same thing on the other side mirrored
yeah cool thanks that helped i have enough space for 2 10's. also if i had to go with 1 frequency that really hits low would 32 be a good one to go with?
Still not convinced? https://gpcaraudio.com/15-dual-high-output-glue-it-screw-it-sub-enclosure/ You can order the box glue and screw kit with...
15
4K
I had two of the Xtreme 12's and they were dual 4ohm. They read at like 3.5ohm per voice coil which is common.
Ive never seen this amplifier before. Can you take a pick of the back? Interesting amplifier.
Hello!I'm in France and I can't register on Hifiengine for unknown reasons and i need to download the service manuals for Blaupunkt Baden Baden...
Of course not bro, I'm having my car transported to you for install.. You are the only person I would let touch my car on the planet.. Should be...
16
4K
DieselFanatic
DieselFanatic
Petaluma, CA
DieselFanatic
