Can I use a single din head unit in my truck?
  • 4
brysonbrantley
I have a 2004 Chevrolet Avalanche and have about $200 for a new head unit. But the problem is that my truck has a double din stereo and I want to know if I can use a single din, and if so how will it be installed to not look messed up. And if anyone has any recommendation on a good head unit I should buy for that price, please let me know. Thanks.
Also needs to have a usb port. Thanks
---------- Post added at 10:51 PM ---------- Previous post was at 10:51 PM ----------
and how much would a dash kit run?
Hell for like $250 you can get a good Pioneer Double Din. But as for decks around $200 that are single din, I would look into Kenwood or Alpine. eBay has some real good deals, and a lot of times, some companies like crutchfield.com, will include a dash kit with your purchase.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
976
Check each speaker for shorts. A pinched wire grounding out or a individual blown speaker can sometimes make the internal amp go into protection.
7
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
650
brysonbrantley
brysonbrantley
Augusta, GA
Buck
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
