Can I seperate a component set?
  • 4
evil_lies
Texas
I want to put a component set it the front of my Jeep Wrangler. I can get an adapter to fit a 5.25" speaker and a tweeter mount. I have found there are a lot more options in a 6.5" set (and sometimes better prices). I need a pair of 6.5"s in my sound bar in the rear, can I use the woofer in that location and keep the tweeters and crossovers in the front and add a set of 5.25"s? I don't think the crossover will know the difference, it just send the lower signals to the woofer, correct? If I do this should I keep the speakers the same brand or can I mix/match?
from what i under stand yes you can. just find out what your crossover is sending to the woofer and get a woofer that can take what the crossovers will give them. also if you comp. 6.5 is 4 ohm then get another 4 ohm 6.5 .
if you do that i dont see any problems.
i kind of split my comps up. right now im running my tweeters of my crossovers and my 6.5 mids off my amp. and ya i have the tweeters/crossovers on the same amp.
So the mids are running active off the amp?
they were, now there back on the crossovers as i have 4 pro 6.5 active off my amp.
need to get another nice 4ch for some 8" midbass speakers . when i do im going to sell my comps.
bit to answer your ? yes i was.
Get 5.25" components and 6.5" mids or coaxials for the sound bar.
You can run the SVC subs on the GM-DX871 at 1 Ohm, just lower the gain at the amp. The third sub is too different to run on the same amp as the...
I’ve tried it in 3 different vehicles and multiple locations. Rear deck is best for me. Unless it’s a midbass I don’t want anything in the rear...
10
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
995
evil_lies
evil_lies
Texas
trumpet
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
