Can I run a marine battery under the hood?
  • 4
As far as I know Marines are deep cycle which is pretty similar if not the same as some of the popular mobile audio batteries.
If my cars stock power and ground are on the big posts, can I use the secondary screw posts it has for my ring terminals?
Sure can..Iuse dual post AGM batteries..I have been looking at an Excide marine battery for my neighbors truck that Academy sells here for like $99.99,bt only comes with a 1 yr warranty:crap:
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
You should run all exact matching subwoofers in one singular enclosure and 1 amp or matching amps for the best listening experience for the space...
11
I am out of the car audio world the more my ears age. However, I am very much still a hobbyist in the electrical field. With much of my current...
15
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
ChucklezZ
ChucklezZ
Patton, PA
AVX Mike
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
