Can I put a system together with this budget?
itsblown
why is there smoke?
1,164
Toledo OH
My friend knows im in to car audio and asked me what I would pick out with a $500 budget. we have to use a line out converter because of the way his climate controls are integrated into the stock head unit. he wants 1 sub no bigger than a 12 and a component set in the front amped. More focus on the speakers then the subs in terms of quality. Can we make it happen for under 500?
500 ill get you a xfl 12 and vfl 4480 amp with a 4 gauge amp kit and loc shipped from me and new .could have the amp and sub at your door in 1 day wires in 3-4 days
need to focus more on the speakers than the sub stage, we can build the box
Said he also wants components. I think his best bet would be a 5 channel, used sub, madisound selection of mids and tweets. That's what I would do but what do I know
I actually tottally over looked the possibilty of a 5 ch, thanks for the tip, what exactly is madisound?
what would 350 get me component and 2ch wise?
a set of cdt hd 61 components and i have a used arc audio kar 200.2 i can do for 260 shipped and an amp kit for anther $35, or the same components and a ph 4100 for 370 shipped all new
Id grab the Eclipse SC6500's for $125 on eBay, a Cache COE6 6 channel LOC for $75 on eBay, a 4AWG amp kit, a Jensen KA5 on eBay for $150, and something like a Dayton HO10 in a sealed box.
He will have a great sounding system for relatively cheap.
You can find some Old school Used amps that Are SQ/SQL oriented for your Front stage pretty Cheapies,and very Under rated power/Clean.Most 5 ch amps are Very Expensive, as where you can look to find a decent 2ch,for front stage, and a 2ch to bridge mono @2ohms on a single DVC4 ohm 8/10/12,or a 4 ch to run in 3 ch mode even,and more than likely will save you some money there for power.I dont think we have heard just as to What Vehicle this is going in as well may help with Speaker suggestions.
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
609
I think he wants to use the existing enclosure he has, and its cut out for a single Ten inch sub at the moment
19
3K
I always planned on installing switches in the remote to the amps to shut them down when I want to. Admittedly I’ve never gotten around to it. An...
6
I have a set up but am looking to hide my amps, I have a 2004 sequoia. Does anyone have a set up like this or pics of an installation?
itsblown
why is there smoke?
itsblown
Toledo OH
itsblown
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
