Can I make this setup work?
  • 3
keezy235
Hey everyone,
I currently have a Cadence DCA 4100 powering two image dynamic component speakers (CTX65CS) in my front doors. Since this is a four channel amp, is there someway I could bridge the other two channels that aren't running my front door speakers and tweeters to power something like an 8" alpine? If this is possible, would the subwoofer be running at 4 ohms or 2 ohms or would it depend on the subwoofer and the way it's wired? I listen to quite a bit of hip hop so I'd like to able to feel my music a little more. Also, if this bridging of the two channels is possible, do you think alpine's new 8" Type R in a ported enclosure (product number: sbr-s83v) would be a good match for my amplifier and my taste of music? I'm up for any reccomendations! Thanks a bunch for your help!
Specs say 250 WRMS @ 4 ohms. The amp should have a little diagram just above the speaker terminals that says either bridge or mono, but you simply connect your positive wire to the positive of the first channel and the negative wire to the negative of the second channel.
ok sounds good, apparently the new alpine type R 8" package (SBR-s83v) with the box only comes in a version which the sub is wired at 2 ohms :/ does anyone have any other suggestions for a quality sub that will run at 4 ohms and needs about 250 RMS? I'm definitely looking to go the ported route for the box because I listen to quite a bit of hip hop. Thanks a bunch everyone!
Edit: also, does anyone know anything about the audioque sdc2.0 series?
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
6
586
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
990
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
7
907
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
keezy235
keezy235
Indianapolis, IN
keezy235
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
