was not was
Banned
where I can find the ground wire?
it was suggested as a solution in my other thread but no one said where to find it.
It's the same thing as power wire, if you're asking where you can buy ground wire.where I can find the ground wire?
That explains the situation much better.This isn't a hobby. my brother put the radio in. i just came here for help with a problem. someone suggested checking he ground. now i need to know where to find thjat.
You need to find the manual for your flipout HU, then look at the included wiring diagram to see which wire is the ground coming out the back of the HU.
Then locate a new spot for the end to come into contact with bare metal (scrape/sand, get it shiny) then use a self tapping metal screw and tighten it into place.
Or, (I read your other post) those DVD HU's have parking break sensors that disable the playing of videos unless the brake is on, which could also be the problem.
The install diagram in the manual should tell you which wire that is as well.
