Can a song that is clipping damage my sub or amp?
Goofyah car
Hello i just installed my new two 15's subs. They are connected to 3000w amp.
I was looking for a good demo song, then i came across a good rebassed song that ''shakes'' my car the best out of all other tracks. The problem is that the song is clipping when i checked it on audacity. Can this clipping cause any damage to my sub or amp? The amp has a clipping indicator and it has not come on while playing the track at max volume. Should i be concerned? should i stick to tracks that dont clip at all? Its just that, tracks that has a ''good bassline'' doesnt do as well as the track that was clipping.
The track:
Sounds like it's not being played at normal speed either. If you want music to "show off" your system with don't start with some shitty youtube video.
Buy or pirate something in a high bitrate/lossless/etc. format. """Clipping""" aside, you probably didn't spend thousands of dollars (or whatever you guys use for money there) on audio equipment to listen to some poorly recorded and highly compressed music files.
That all said, your woofers can only take so much heat and they don't care so much about the shape of the waveform you play but only the average amplitude over time.... or in other words, if it sounds like something is stressing or you start smelling something burning turn it down!
Okay thanks! That was the answer i was looking for. Btw what is the best audio format i should export/listen to? Im trying to rebass by my own so it would be good to know.
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
861
Don't recall off hand. Both single dins. One excelon, one not.
968
1. make sure you wired your subs right... https://jlaudio.zendesk.com/hc/en-us/articles/204374200-Dual-Voice-Coil-DVC-Wiring-Tutorial 2. set...
10
Even a basic TL072 will do this function just fine. LoL. The joys of comparators!
34
6K
I would pull the HU and bench test it. Can be done with a 12v battery on a non-metal work bench easily enough.
16
Goofyah car
Goofyah car
Finland
Goofyah car
Decebal
    Jun 10, 2024
