Cadence ZRS-8000D pair for sale new and used
  • 4
art1618
for sale are two 8000ds the two on the boxes are the good ones, the other two need repair. I WILL NOT SEPARATE THE PAIRS. i need the cash to repair the busted ones and sell those too.
one is new in open box, other has few hours on it. i only have one bass 'mote and i have the link wires for them.the boxes are kinda messed up from moving apts so much. tired or dealing with CL dbags. i have a 250 amp alt that drops in a 05 scion xb and same motors. i sent it to MM and it got repaired and was not installed since. dont know if it works honestly. if enough interest ill correct post. 8 rib pulley, has a bracket and harness for a 02 ram.
TRY ignore my rediculous laugh.
sub wasnt in a box so obviously didnt take much power to mess it up. the amps used there are the ones that are busted now.
SPECIFICATIONS:
4 Ohm RMS Power: 1 x 800 Watts @ 13.8 Volts
2 Ohm RMS Power: 1 x 1400 Watts @ 13.8 Volts
1 Ohm RMS Power: 1 x 2000 Watts @ 13.8 Volts
IHF-2002 Peak Power: 1 x 4500 Watts Max @ 1 ohm
Two Z8000D bridged together = 1 x 4500 Watts Max @ 2 ohm
Frequency Response: 10Hz - 400Hz
S/N Ratio: >100 db
Damping Factor: 230 @ 100Hz
Minimum THD:
Input Voltage: 200 mV - 8 Volts
Dimensions: 17.8" x 9.4" x 2.4"
FEATURES:
High Speed Mosfet Power Supply
Bi-Polar Japanese Sanken Output Devices
Copper Rail PCB Architecture
24 dB Crossover Circuitry
Fully Adjustable Low Pass Crossover
Low Pass Crossover: 50Hz - 150Hz
Bass Boost Equalization: 0-18db @ 45Hz
Subsonic Filter: 15Hz - 40Hz
Lucite Encapsulated Large 4 Gauge Terminals
Soft Start Mute & Delay
Dual-Amp Bridging for Double the Power @ 2 Ohms
Master/Slave Control
Adjustable Phase Control
RCA Line-In/Line-Out Jacks
Includes Dash Board Bass Remote
$800 for both or $1k for all 4. hope price is reasonable. the amps are too costly for me to repair. im broke. amps are 16V capable. if you fix em its 9kw of power for a grand. i just dont have the moneys anymore.
i typically use UPS. choose. ships from 79938
View attachment 26527342View attachment 26527341View attachment 26527343
they do lots of power, unfortunately my stupid as s burned to mosfets on one and a little resistor on another. somehow both SOBs still work when they are master slave configured. weird.//content.invisioncic.com/y282845/emoticons/banghead.gif.8606515f668c74f6de0281deb475b6fd.gif
We do not have a rating for these amplifiers at .7 ohms because we do not test below their minimum recommended impedance.
The ZRS8000D @ 2 ohm – 1400 Watts @ 112 amps
The ZRS8000D @ 1 ohm - 2240 Watts @ 189 amps
Best Regards,
Gregory Jantos
Engineering Technician
6519 Highway 9 North
Howell NJ 07731
732-370-5400
Best Regards,
Gregory Jantos
Howell NJ 07731
732-370-5400
Best Regards,
Gregory Jantos
Howell NJ 07731
732-370-5400
soooo... @ 14.4 volts more power? @ 16v?
let just say for sh*ts and giggles
13.8 *189 = 2608.2? watts
14.4 *189= 2721.6? watts
16*189= 3024?watts
thats if it pulls the same amperage? and the amp efficiency dont drop as much. i dont know someone enlighten me.
Glad you got your ads up and running. Good luck with your sales. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
Get your Coupon RIGHT NOW!!!🥳🥳🥳 Let’s celebrate the upgrade of Cadence Sound Website! Take this chance to get the 10% OFF coupon which has no...
art1618
art1618
el paso tx
art1618
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
