buzzing noise HELP
  • 2
obivouslyasd
i blew out one of my front speakers a couple weeks ago and it ruined my amp. there was a buzzing noise after i blew it out, with the ruined amp, and now i got a new amp from my warranty and the buzzing noise is still there. the noise is there when i have only the battery on, but not as loud. it gets louder when i rev my engine. i haven't checked my head unit wiring yet, just in case it can be fixed without removing my whole front panel.
oh and i don't have any front speakers hooked up right now
the noise and sort of shows my wiring
Speakers buzzing - YouTube
Double check your ground and make sure it is secure and sanded down. Also, are your RCA's and power wire ran on the same side on the vehicle
the rca's are on the right with the speaker wire and remote and the power wire is on the left, all by it self; however, the ground cables touches the rca cable right at the amp, is that a problem?
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
obivouslyasd
obivouslyasd
United States
obivouslyasd
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
