Broken Rear Amplifier NEED HELP!
  • 5
Andrewneep
To begin this post, I'm a lazy idiot, and that's why my amplifier is broken. So there, I said it.
You see, I was exploring different ways of wiring my sub amp in parallel with my rear speakers, when, long story short, I shorted out the output on my rear speaker amplifier. I have a nissan maxima with the bose stereo in it. If you're not familiar with it, there are amplifiers attached to the bottoms of each of the rear speakers. Now when i turn it on, it makes a repetitive clicking noise and no other sound comes out of it. Also the noise doesn't get any louder or quieter if i adjust the volume on my radio. I am considering repairing the chip myself, but i'm not sure what exactly blew in it. Does this sound like the transistors are blown or is it something else?
Maybe Im a bit off here but I didn't think amps unless controlled by a digital disply had a "chip" so I'm a bit confused, but if Im right right then you definitly have no business rootin' around in your amp.
Take/send it to a pro or instal some nice new speakers powered by a decent amp.
And also, Welcome to the forum
Whatever i shouldn't have said chip i meant circuit board. Basically all I'm asking for is a diagnosis. Based on the symptoms i gave, what components should i replace on the circuit board if i attempt to repair it myself? Transistors? Capacitors? Both? And I'd send it to a pro, but if i can diagnose it myself and repair it myself for just a few dollars, i'd rather do that than pay somebody.
Have you ever worked on a circuit board?
If the answer is no, then you shouldn't even be contemplating repairing this yourself.
BTW.. have you cheacked all the other fuses? Possible a fuse blew.
yes i've worked on plenty of circuit boards before and even made my own. And yes i checked the fuses. Originally the 15 amp fuse in the dash fuse box blew because of this and none of the speakers worked. But i replaced it and now it's just the one that got shorted out that's giving me trouble.
you'll need to bench test the speaker/amp and use an oscilloscope to trace the signal and find where it is lost. likely the short caused damage to the output transistors since those factory amps didn't need output protection. but when a transistor is damaged, resistors likely follow.
it would be easier to just grab a replacement from a salvage yard.
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
5
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
3K
940
Andrewneep
Andrewneep
Milwaukee, WI
keep_hope_alive
Decebal
    Jun 10, 2024
