broken basket on xxx
misterio
texas
Is there any way to fix a broken basket on a xxx 12" 2002 model? It is cracked in two places and is bent toward the bottom so if i installed it like that it would leak major air. I hope I can get this fixed it stinks.
thanks
Is there any way to fix a broken basket on a xxx 12" 2002 model? It is cracked in two places and is bent toward the bottom so if i installed it like that it would leak major air. I hope I can get this fixed it stinks.thanks
If you aren't confident in your welding abilities... which welding that close to a sub would make me extremely nervous... i would say call the company and ask them how much it would cost to get a new basket. I am currently getting my XXX re-coned and they give pretty good prices on the parts to fix stuff with
problem is that it is broken in two spots and now it is sagging down which prevents it from having an airtight seal
JB weld comes in tubes. No actual "welding" involved. Just squirt the tubes together and put it where you need it.
i know except im pretty sure that if i actually tried to weld it with a welding machine.
1. sparks would melt through the surround
2. the heat would melt the surround off
3. etc
it's why you use JB weld epoxy type stuff (if it isn't bent).
i've used JB on tons of stuff.. holds like no tomorrow, and i heard that they fixed a cracked engine block with it. //content.invisioncic.com/y282845/emoticons/silly.gif.3549b64aaa5b6729eb8e865319a3234f.gif
So the car audio shop I took it to just claimed "bad wiring" and now it all works. Not really sure what that means but case closed! thanks...
14
Sounds like it's the digitizer in front of the LCD panel (a separate clear thin glass panel that responds to touch) is what broke. Technically it...
OK, so turn your music on at moderate listening level and unplug the battery/alternator and see how long that capacitor keeps things playing...
19
Looking to buy 1 Soundqubed hdc4 15” basket/ frame with gasket.
  • Locked
Negative 1aespinoza . The spider landing is to big on the newer 12 spokes like you posted . I need the old school 12 spoke. Nobody here has...
misterio
misterio
texas
gellis4
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
