Bridging, Still dont get it...
Kastlez_
Bay Area, CA
This is the first time i've ever dealt with a class a/b amplifier so bare with me.
Everything is already hooked up but i had a few questions about fine tuning to make sure its all good.
AMP: mm 100.4
Bridges @ 4ohms
It's bridged like this:
I have the rca's from the H/U plugged into line output CHANNEL 1 & CHANNEL 2 only??? does it matter that channels 3 and 4 are left out
* Switch is turned to MODE: 2 CHANNEL (vs 4 channel)
* Gains are matched channel 1&2 with channels 3&4 (correct?)
Yeah that's all.. input is appreciated
you got it wired right.
i never ran it bridged, but i think its supposed to be ch 1/4 for RCAs(at least was when i wired up a MBQ amp)
I've tried a few different combinations they almost seem to sound the same.
Any second opinions about the RCA outputs?
Thats what im thinking because it seems like they arent getting enoug power even though bridging is supposed to increase rms to (2) channels at 4ohms.
I tested checking the balance but both sides are audible even switching back and forth from my h/u
Im going back to only using two of the four channels.. briding just isnt working for me
That amp does not have the RCA summing feature. You will have to use RCA splitters at the amp. If you already have that, then check the gains.
960
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
Toyota is really efficient. Usually the life of a Toyota last 18 - 25 years before the car or truck begins to wear down. 25 years then fixing...
16
i would recommend placing an amplifier on these to serve any justice at all https://www.polkaudio.com/en/product/mm1-series/mm6502...
11
Kastlez_
Kastlez_
Bay Area, CA
Kastlez_
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
