Bridge front speakers?
  • 4
butterMilk
BC
Currently I am running a JL XD 400/4 with Imagine I61-2V2 6.5 up front and stock speakers in the rear doors. Im thinking I want to just run the Imagines up front, but bridge the amp to the front.
To do this can I... use RCA y splitters , and send the left signal to the front channel, and the right signal to the rear channel. So I could bridge each speaker.
Amp specs.
75 watts RMS x 4 at 4 ohms (100 watts RMS x 4 at 2 ohms)
200 watts RMS x 2 bridged at 4 ohms (4-ohm stable bridged)
Would I still get proper stereo sound doing this? Am I going about this the right way?
If you read the amplifier manual it should say where you need to connect the rca cables and NOT need a y connector when you run the amp bridged.
Usually if you bridge a 4 channel amp you send the signal into channels 1 and 3. (Not into 2 and 4.)
If you read the amplifier manual it should say where you need to connect the rca cables and NOT need a y connector when you run the amp bridged.Usually if you bridge a 4 channel amp you send the signal into channels 1 and 3. (Not into 2 and 4.)
Im using a aftermarket HU, AVH p8400bh
I wanted to use 4 channels so I thought I would have to use "y" splitters (bridge the front 2(L/R)', to one speaker, and same with the rear)
The owners manual was a good idea lol, it told me to use "y" adapters.
If that's what it says //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif then Y it up.
Could only find monster cable splitters, though I didnt look very hard. 25$ each fml. But they have 24k gold connecters, so its worth it right lol.
3 ohms speakers are generally what some manufacturers do with factory systems, and wire the components in series. If your amp can do 2 ohm and 4...
5
If I didn't have my two 4500s already I would probably try the Creampie 7500/ Slapz 8k. :poop:
The question is confusing. Connect the 4" to the radio and use the rear amp channels for the sub. If the sub is DVC you can also use it in stereo...
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
795
butterMilk
butterMilk
BC
keep_hope_alive
