Box size?
  • 2
RMF419
Can someone run these specs thru their box building program and see what size box it comes up with. I am coming up with a huge box. Thinking these may be good IB subs. these are the numbers. It features dual 8 ohm voice coils, poly cone with rubber surround, vented pole piece, and bumped magnet back plate. Specifications: *Power handling: 150 watts RMS/300 watts max *VCdia: 1-1/2" *Le: 1.24 mH *Impedance: 4 ohms *Re: 2.65 ohms *Frequency response: 27-1,000 Hz *Fs: 27 Hz *SPL: 86.5 dB 1W/1m *Vas: 3.15 cu. ft. *Qms: 9.83 *Qes: 0.65 *Qts: 0.61 *Xmax: 6.0 mm *Dimensions: Overall diameter 10", Cutout diameter 9", Depth 4-1/2". Note: All specifications are with voice coils connected in parallel. Thank You...
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
409
RMF419
RMF419
Toledo Ohio
RMF419
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
