box size, cannot understand specs
  • 1
alex6999
going to make boxes for AMD60Q
specs here.
http://www.audiobahn.com/Audiobahn06/images/tech/2007/boxParams/AMD.pdf
it says total volume - 0.75 ft^3
min volume - .15
max - .25
i cannot understand what is correct one. maybe first one(.75) for ported box, and
(.15-.25) for sealed box? am i right?
port tuned to 38 Hz, but i going to use this speakers as midbass, 30-500 Hz
and use separate 12" sub
that box will be better in my situation? ported or sealed?
if sealed, what volume better? .15 . 20 or .25?
maybe stupid question: can i change port frequency by only changing port size from 2*6.5 to 4*6.5 :-() .... I need 80Hz.
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
5K
I'm trying to do 4 18 inch resilient sound platinums in a cpillar flat wall .4 to 5 cubes per was told they like 12 to 16 inches per cube . I have...
40-85l is about the size range most high powered 12" woofers will want for a box. You should use manufacturer suggested box specs unless someone...
I would like to a bandpass box wherein the subs are facing each other and each have their own sealed enclosure with the center section being the...
alex6999
alex6999
Toronto, ON
alex6999
