Boat audio help!
  • 2
Maxwellloop
CarAudio.com Newbie
So I’m trying to do a sound system in my boat, wanna DIY it to keep it relatively cheap, but I want good sound. (I’ve done plenty of emergency light wiring)
But not sure what to pick as an Amp, and how to wire it right... The speakers I bought are JBL 6.5 inch, 4 ohm with 60W RMS... and the subwoofer I have is an 8 inch Rockford 8 inch, Dual coil 4-Ohm with 150 Watts RMS. And the head unit is a Garmin 010-01716-00
I think I want the speakers and the sub to both have Amps
Also the Ohms thing confuses me... with the different types of wireing up the speakers to stay within the Ohm rating. So if someone could recommend an Amp or Amps and tell me how to hook up everything that would be much help!
Thanks for the help!
So two speakers and a single subwoofer?
The subwoofer being a dual 4 ohm makes it to where you have to run it at 2 or 8 ohms. Most 4 channels are not stable bridged at 2 ohms.
Soooo 5 channel amp would be your best bet.
Pioneer GM-D9705 is what I would do. Subwoofer at 2 ohms on the subwoofer channel and the two speakers on channel 1 and 2.
No reason you couldn't just glue a ring of plywood up under there then paint it with some bedliner or plasti-dip or similar to keep the elements...
6
A Link would be very helpful. Id be interested in taking a look at some gear
206
Excellent like new condition, with minor blemishes. DSP plus 8 channel amplifier in one. $1299 shipped. $1799 plus tax brand new
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
334
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
Maxwellloop
CarAudio.com Newbie
Maxwellloop
Seattle
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
