Blue/white, relay, extra wires? multiple questions
  • 2
Selvos
14
Europa
So I've recently removed an old aftermarket stereo from the previous owner and installed a new one...pioneer x1500dvd. I have a few questions
1. Where does the blue/white wire on the pioneer harness connect to? I actually used a relay to bypass the brake and connected it to pin 85...DOes that go out to the blue wire on the metra harness?
2. Can I splice in a ground wire to an existing ground wire that already has another ground spliced in? There is a random black wire which I have no idea where its from, but I figured I should ground it.
3. I have a left over cable. I have no idea what it is. I have connected the subs, front and rear speakers. What could it be to? It looks like it was cut and fitted with a speaker connector.
4. There is an old Pac steering wheel control. I disconnected the harness to it and removed the box, but there are several red and black wires still left. Can I just leave them be?
5. THANKS SO MUCH. I'm new to this, but I've learned so much.
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
You've read an outdated book...most of us learned things by either trial and error or someone more experienced helping...not a 20+ years old book 🤣🤣🤣
11
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
Selvos
Selvos
Europa
Selvos
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
