Blue top or yellow top?? difference?
  • 3
casper97ta
IM HERE FOR THE GANG BANG
I know the blue top is for marine. but the dual purpose marine looks like a better acc. battery than the yellow top. plus it has the wing nut term. for acc. any reason everybody uses the yellow top instead of the marine dual purpose?? i know the blue top is more expensive but i think the marine dual purpose is a way better acc. battery
they are the same thing //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif blue is more corrosion proof thats about it, they perform exactly the same
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
748
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
Some equipment like AMPS comes with it no owner's manual. So the lights blinking on or off has to be taken somewhere else. Search engine. Car...
You've read an outdated book...most of us learned things by either trial and error or someone more experienced helping...not a 20+ years old book 🤣🤣🤣
11
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
casper97ta
casper97ta
Pittsburgh, PA
helotaxi
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
