SOLD Blown Soundstream PCA2000d
  • 1
Optimus_Prime
1. Product: Soundstream Pca2000d
2. Specs:
* Peak Power Output: 4000 watts approx.
* Monoblock Picasso Series Amplifier
* RMS Power Ratings:
o 1100 Watts x 1 Channel @ 4 Ohms
o 1500 Watts x 1 Channel @ 2 Ohms
o 2000 Watts x 1 Channel @ 1 Ohm
* Bridged RMS Power: Not Bridgeable
* Min. Impedance Unbridged: 1 ohm
* Min. Impedance Bridged: Not Bridgeable
* THD @ Rated RMS Power: 0.5%
* Speaker Level Inputs: No
* Amp Preamp Outputs: 1 Pair
* Built-in Crossover: LP (50 - 150 Hz), Subsonic (15 - 40 Hz)
* Bass Boost: 0 - 18 dB
* Signal-to-Noise Ratio: 80 dB
* Fan Cooled: No
* TST (Twin Stack Technology): Allows 2 Amps to Drive One Voice Coil!
* High Quality FR-4 Circuit Board
* Class D Circuitry
* Continuously Variable Low-Pass Crossover: 50 - 150 Hz (24 dB/Oct.)
* Continuously Variable Subsonic Filter: 15 - 40 Hz (24 dB/Oct.)
* Variable Subwoofer Equalizer: 0 - 18 dB
* Phase Control: 0° / 180°
* Frequency Response: 5 - 250 Hz
* Adjustable Input Sensitivity: 0.5 - 4V
* Damping Factor: >200
* Fully Regulated MOSFET Power Supply
* PWM Circuitry
* Platinum Power and Ground Connectors
* Accepts up to 16VDC Power Input
* Wire Bass Remote Included
* Dimensions: 18" L x 9-1/2" W x 2-1/2" H
3. Description/Condition: Blown / Not Working
4. Price: :150 Shipped OBO
5. Pictures:
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
968
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
4K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
Optimus_Prime
Optimus_Prime
Albuquerque, New Mexico
Optimus_Prime
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
