Blown Polk DB651 speakers
  • 2
Verbalkint99
I have a set of DB651s speakers in the front and DB651 speakers in the rear. The are running through a Pioneer HU and an Infinity Reference 4 chan amp. Both the front and rear right speakers have lost their lows, while retaining highs. Both left speakers are fine. I hooked up a known good speaker to both amp ports to rule out the amp and wiring. Same symptoms with the test speaker no lows with clear highs.
On the DB651 the capacitor lead broke so I am thinking I can re-solder it, but on the DB651s there is no visible damage.
Are either of these salvagable?
What amp and Ohm load are you running? What are the dimensions of the enclosure? sealed or ported?Tuned too? You may be better off buying a pair...
994
  • Locked
I have a zapco 4.0 and 6.0 that was stored in an area near the beach and corroded it pretty bad. Never was powered since it was stored working...
14
5K
Everyone I found the problem it's the RCA cables, I had my electrician mate have a look and he pulled one of the cords halfway out and the subs...
14
Verbalkint99
Verbalkint99
Macomb, Mi
dthor68
Decebal
    Jun 10, 2024
