Blaupunkt BT420 Sub output.
  • 3
eurotrash
8
Ohio
Hey all, noobie with a non-rca sub out offering on a head unit. I have a Blaupunkt mono amp with only two RCA inputs..no high level. I tried a couple of search phrases and didn't get a hit for the Blaupunkt Toronto head unit.. so is the output from the head unit considered high level, and need a converter? I assume so, but didn't see this coming when ordering parts from the manufacturer. :/
Thanks in advance guys..
Gotcha. Well the head unit has the (blue) remote wire.. so I'm torn. This is for an installation in a very old car that has many moving parts as it is, adding another box is less than advantageous, unless absolutely necessary.
I assume the sub out is a high level situation? Is that given, because of the type of connection it is?
I also thought about just running RCAs off the front channel outputs to the amp, as long as doing so doesn't change anything at the speaker outputs.. but then full range to a mono amp...??? I'm really lost
thats the thing! the head unit has RCAs for the front channels but not the sub! The sub amp takes line level RCA, no speaker inputs.. so can I run positive off of the left channel RCA, negative off of the right channel RCA to the sub amp, let the crossover in the amp do the work and call it a day?
sorry to be a pain man. thanks for the help. If you think that's a fine solution, then I will go that route. Its just a JL 6.5" sub.. not like its going to 20HZ or anything..
Yup, that'll work, or you can just splice into the rear speaker wires at the pillars in your vehicle and run an rca from the converter to the amp that way. Doesn't matter which way you do it, you'll just need a longer rca if you tie in behind the radio.
thnaks again I could not find this product in europe so I will go with this one ...
10
Lookslike the amplifiers recommended should work just fine with Either Chs 1&2 or 3&4 bridged/mono mode/LPF should work just fine as well as using...
16
4K
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
423
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
431
eurotrash
eurotrash
Ohio
UsAmpsFreak
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
