Big 3 upgrade
I just don't feel right using welding wire it may work fine but just want everything done right and not have to replace it for a while. I looked at the kicker 0 wag is it good wire?
2/0 welding wire is better then any type of wire you could use. Think about it. Welding wire is capable of holding 600volts. without getting hot or melting. O guage wire like kicker rockford fosegate and other brands can not handle that kinda of voltage. If wire incorrectly it will melt and cause other things in your car to get hot also. With welding wire you have no worries especially since you are using it as the big 3 ground wires.
i know nothing, but this guys right.
lul
Local welding supply or marine/RV is a good supply for heavy gauge wire. Welding wire is designed to be flexible, drug across floors, etc....durable stuff. Most welding wire is OFC instead of some type of plated aluminum (Knu and others lower lines of wire).
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
963
Ok I didn't really think it mattered because ground is ground just wanted to be. Sure. So I'll do alt to bat, batt ground to alternator mount, and...
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
elballz12
elballz12
Decatur, AL
Ninesvnsicks
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
