Big 3 Questions and Concerns with plenty of pictures
  • 4
Sweet'n Low
Harshaw
I took my battery out and took a look at what i was dealing and a lot of questions came to mind.
"7) Attach the wire along the way to something that won’t get too hot and that won’t vibrate too terribly. Go ahead and connect the wire to the positive battery terminal"
Slymosickle
one going to my trunk for my amps
Mine already has 3 things connected to it. Is this unusal or am i just not thinking this out?
Next I'm having a hard time finding a chassis ground. for both my engine block and negative. I've got a couple ideas though.
are either of these good?
next
"8) The last step is the Chassis to Engine Block wire. Remember to sand both points well, just like the when you did the Battery Negative to Chassis. All you need to do for this step is to find a non-essential bolt on the engine block to attach the wire to. Non-essentials are those that don’t hold a liquid in. For example… using the Oil Drain plug as an attachment point probably isn’t the smartest place."
Is this a good point?
Should I be concerned about the battery acid on my terminals also? I feel like i'm going to get a block anyway so i shouldn't worry about it. Also, how do I find my alternator? don't see it anywhere...
I know this is kind of a load and i still feel like im forgetting something but i'll go with this for now. It'd be a load of help if i can get some feedback. This will be my first time really going hands on when it comes to my stereo seeing that I had best buy install in originally.
i also feel that i should add that the factory alternator is 130 amp and has 4-6 gauge wiring stock, and if this is earlier than a 00 or a 00 then you should also take the voltage sensing wire and wrap it around the main charge wire to eliminate any dimming you may encounter due to factory crap, obviously high amperage aps require the proper treatments...
your engine is so tricked out compared to my stock lol hard to compare but i get the idea... did you have a hard upgrading your system with the wire locations? And how did you mount your amps to your seats? the backs of mine are straight steel (or aluminum..i think steel).
my install in a trainwreck at the moment, but i previously had self tapping screws shot into the seats...currently going with an entirely new set-up with no more rear seats but a huge flat floor!
Couple Questions..
can you go into more detail about that? what voltage sensing wire?
how do you suggest i get to the transaxle for the engine block ground to chassis(or negative) upgrade? did you hook your new wire back up to the transaxle or find a new spot?
where is my negative battery ground?
what did you mount your fuses on and how? is it necessary?
where is the alternator and how do i locate its positive when i find it?
its all difficult to explain, you should take a notepad outside, pop the hood, and make notes at ideas and thoughts and different options and then make a decision mayne!
Couple Questions..
These are some pretty serious questions. The alternator is driven by the serpentine belt. Buy a Hayne's manual for your car so you can look up the locations of parts, and their installation/removal. Here is a thread that will explain the big 3 and how to make proper connections (with lots of pics):
http://forum.sounddomain.com/ubbthreads.php?ubb=showflat&Number=1804618&page=1#Post1804618
I don't like the ground locations you showed. remove the battery and the battery tray. under the tray, on the frame, is a perfect ground location. you can trace the battery ground wire to find where it is attached, there may be more than one, the one to the frame is the one you upgrade, not the body.
2012 Civic Si, and yes 4awg, didn’t see a need to go 0/1 since I’m only installing the mono D amp the subs, anything further would require...
958
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
I will still find the blame..Bad tool, cheap connectors, junk wire..LOL 🤣 🤣 I didnt have enough B12 this morning is my favorite
23
Sweet'n Low
Harshaw
Sweet'n Low
Springfield-Dayton, OH
Sweet'n Low
    May 31, 2024
    May 24, 2024
