Best place to take inputs from on a 16 Sierra w/ Factory bose
  • 2
timbo-slice
CarAudio.com Newbie
Hey guys, I'm new to the forum. I hope this isn't a repost but I have scoured the web trying to find some insight on this.
Here is my setup:
2016 GMC Sierra denali crew with Factory Bose with 8" console sub and bose amp on the rear of the cab
I am running 2 JL 12TW3-D4s in a sealed box under the rear seat powered by a JL HD750/1 and an Audiocontrol LC2i.
I currently am taking my signal tap from the right rear door speaker leads, into the LC2i, and into the JL amp. It sounds ok with my LP set @80hz (24db slope), (30Hz infrasonic filter is OFF), but I feel like I'm still missing the really low end notes. Gains are all set properly using a 100hz PSW test tone and there is no clipping.
Should I be taking my amp inputs from the factory sub leads and just disconnect the factory sub completely? I can't find any info on if the rear doors would be a better signal tap and what the factory bose amp tuning is set up to as far as filtering goes. I have the accubass currently disabled until I can find someone with a proper RTA so I can accurately set it.
I am thinking leaving the factory sub hooked up will help me with getting more dynamic range out of the low ends to compliment the added subs.
Again, sorry if this is a repost.
That's a tough one to respond to. I would have to hear the stereo to give recommendations. Have you tried having a friend listen to your setup? First, with the factory sub disconnected. Second, with the factory sub connected. Just a suggestion.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
700
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
12
599
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
776
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
timbo-slice
CarAudio.com Newbie
timbo-slice
Edmonton, AB, Canada
huberoy123
Decebal
    Jun 10, 2024
