Best 15" sub for music on 3k
I've looked many times and the CF looks very simular also. The Evil looks to have a smaller diameter motor but stacked higher. They are to simular to call much different
Evil is closer to a xsv2 not an sp4
I think the evil uses 4 spiders and the xsv2 uses 5 other then that they "look" almost identical
Yes, the baskets are the same but how are those motors even similar? lolCan you tell them apart?
So it has a extended plate but it looks to be the same height and the same amount of ferrite. Does that really change it that much? I'm not a sub designer so I don't know
Really ? I guess your 9512 is the same as a hdc then huh ? Your statements get dumber everytime I read them..you mix a little knowledge with a lot of stupidity and some nuthuging tossed in ..
It more along the lines of the new XFL looks wise. What else do you have to say? I have ran enough stuff to nuthug what I've found most effective, what about you?
What's with the obsession with FS? There is alot more to a driver than fs. All FS indicates is free air resonance. As soon as the woofer gets put into a box it's fs changes, and ported setups make FS even more useless since then the resonance of the enclosure is dominating the response.
Regardless the SP4 should be good for your application. If your willing to wait a few months the Sundown Z4 seems like it would be RIGHT up your alley as well.
I've ran enough to know most of what u say is bullshitt
So you are another one of those people that talk **** with nothing to back it up? i may not always explain things 100% correct but at least i try to get some kind of point across. Instead of just saying "its good".
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
967
677
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
566
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
730
Search Amazon for the Dual DCPA701W I had it for about a year and it sounded and worked flawlessly. It was very clean sounding, especially for a...
16
mugen08
Win aplenty
mugen08
Outside the box
rebelfromva
