Best 10" subs 5.25" mounting depth.
de8212
georgia
I may buy a pre-made sub box online or get the local shop to build one but the maximum mounting depth of the box online is 5.25". Here is a link to the box.
Ram Box
Here is a "slim" 10" the local shop suggests.
RF Slim 10"
I don't see a whole lot of people running RF subs so I looked at RE sub specs. The RE SE 10" shows 5.25 but I'm not sure if that would literally be flush with the back of the box. Doesn't there need to be a little room behind the magnet?
And the optimal enclosure shows .5 but I am thinking the box is .7.
Only other issue is the pre-fab box has the subs firing downwards. I would think that would make the bass "rumble"more where as I would like it tight. Not sure if I am correct though.
Any other suggestions?
well your going with a sealed enclosure wich on most occasions will give you a nice tight response. one way to help you get good tight response is feed it a good clean signal with a good amount of unclipped power. now look for drivers that are sq oriented, with all factors taken in to consideration you will get what your looking for. if going for sq as stated then dont go with the rf drivers imo! head towards jl if you have the cash or if on a budget try the kenwood shallow mounts they arent half bad for the cash and they are more sq oriented
as for the down firing enclosure it will be fine, it wont make that big of a differance but it will help give you better output but if installed properly you will have a great sounding install
thank you for the reply.
SQ is definitely what I want.
It has been years since I've had a JL sub. Looking at their site the only ones that would work is the 10W1V2.
Are they decent compared to the higher up models? Any other brands recommended?
EDIT - And if I went with something like the JL W1 what would be a good clean amp to use?
Since I've been out of the loop forever does JL still not authorize internet sales?
Just wanted to add that I emailed the maker of the box and they said the box is "5/8" wood".
I asked if it was MDF and what the thickness is but they only answered the thickness part of the question.
Wonder if that means it's some cheap plywood?
They're rated for 250wrms, so you were overpowering them, especially the poor 10s. XBL subs sound really clean at their limits due to the flat BL...
10
349
488
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
478
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
586
I hear ya. There are so many good deals on speakers too. My kid is 16, so loud is better than SQ. LOL... I really like the sound of the PPI...
15
de8212
de8212
georgia
Stephen_c
    Jun 1, 2024
    May 31, 2024
