Batteries
  • 6
Fabian12
CarAudio.com Recruit
Trying to figure out how many batteries (ah) needed to properly abuse my zv5 15.
gear: SIA 3500d, Zv5 15, Big 3 + 2/0awg power and grounds , 60ah regular battery up front, and 100ah agm in the rear.
System sounds great into the very loud lows, but kinda breaks up (assuming power drops) when running for more than a minute or 2 at 85% volume then goes back to "normal"
Im trying to figure out how much reserve capacity I need to let it scream at full power for 15-20sec without dropping power. (fyi-voltage does not drop below 14.2 when this issue occurs) advice appreciated
*forgot to add that I also have a 240-280a alternator*
I would start looking at an HO alternator,(250 amp up to 300) keep the stock for Emergencies if needed temp. until you decide on a new HO alt.
What Vehicle and what size is the Stock alternator? Most vehicles you can only get maybe a 140 amp alt. Max. at the local auto parts stores
Then you have a different issue.
I would be interested to see if the issue isn't how he has determined voltage is staying so high trying to run a 3500W amp on factory charging system + only 1 additional battery. I'd consider HO alternator + another 100AH sized AGM would be more appropriate and probably another 100AH AGM on top of that to be a bit more reliable. OR lead acid delete and get into lithium.
I forgot to add that I have a Js HO alt, think its 240-280a. Im in an 08 civic
I forgot to add that I have a 240-280a HO alt, so I guess another 100ah agm in the rear is the best plan. cant think of anything else
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
222
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
NADBL is the org that we get up here in the northeast, they do some shows in Ohio and upstate NY and into Canada, might be close-ish to you...
36
4K
Just the amplifiers use batteries to power it up. The HU are powered up by the car battery supplying 12 volts. The wiring harness...
6
Fabian12
Fabian12
Richmond, Virginia
hispls
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
