Banda Viking 7k with dual inputs
  • 4
wew lad
wew lad inc
6,215
214
VA
Banda Viking 7000 1 ohm version with 18hz subsonic mod
Selling because I'm getting a Bass 12k
Comes with the dual inputs in the pic
Amp is fully functional, USPS broke off one of the mounting feet but it's plenty secure with 3, or you can use a long bolt through the front mounting hole
Yes, these do rated power, 9k at 1 ohm at 14.4v. Do NOT wire it below 1 ohm unless you have known rise and are willing to have it fail on you
1 channel 7000Wrms @ 1ohm / 12,6Vdc ou
1 channel 9000Wrms @ 1ohm / 14,4Vdc
1 channel 5100Wrms @ 2ohms / 12,6Vdc
1 channel 6100Wrms @ 2ohms / 14,4Vdc
Current draw at power: 350 A (average music program)
Frequency response: 18Hz – 8 kHz
Dimensions VIKING 7000: 17.4" L / 2.5" H / 10.1" W The dual inputs add about 3 inches onto the length of the amp
Weight: 7,4 KG
$600 shipped in the continental U.S. OBO
Shipping included. If you want special expedited shipping tell me and we'll negotiate a price.
Pics will be uploaded tomorrow morning when its light out and I pull the amp out. This is just to show I have it and it works
Do these require similar electrical that a Korean 7k would?
I was just thinking about mentioning what it needs, thanks for reminding me.
I clamped 450dca of current draw, depending on the korean board it needs more/less. I find that full bridge amps LOVE capacitor banks due to the lack of internal capacitance. With the electrical in your sig you could run it, but you'd definitely hit 12s. Add a bank of caps and you'll be similar to my electrical and you should be fine
Item(s) for Sale: Banda Viking 7000 1 ohm version with 18hz subsonic mod
Weight: 7,4 KG
Sweet amp
One of the legs broke off, I used epoxy to glue it back in place and it's pretty solid now but obviously I can't guarantee it. One of the fans seems to have broken during shipping, which is a positive aspect to me because its quieter but I'm probably going to order one off of amazon to replace it before I sell it. 3 of the fans still work just fine
In light of these (cosmetic) issues I'm dropping the price to $550 shipped
611
734
Assuming the box is made of .75" MDF the 12"x20"x15" box is 1.5 Cu Feet. The 33"x19"x15" is 4.3 cubic feet, something is not right here. JL has...
945
wew lad
wew lad inc
wew lad
VA
wew lad
